webboyus
Oct 05, 2021Follower
CG3101D VMDG480 Flash firmware for use a switch or hub
Hi support , two questions here,
A) the virgin hub what are the speeds of the ethernet ports 1 - 4 Is port 1 just the 1 Gig ?
I wish to use the router as a Hub or a switch.
Can the firmware be flashed to have some of the basic features to control it ?
CG3101D
1 Reply
This is a unit that is specifically given to Virgin Media ISP services. They will have information regarding it and the specs as they develop the FW for it, not NG.
I presume its close cousin is the NG CG3300
https://www.netgear.com/support/product/CG3300D.aspx
I would ask Virgin Media on spec information and support.
https://bytemyvdu.wordpress.com/2013/08/17/virgin-media-superhub-setting-ip-address/
Good Luck.
