xpender's avatar
xpender
Follower
Jul 01, 2009
change language CVG834G
Heloo,
I get this wireless router CVG834G from a friend but menu language is in french.
And i`m stuck in here.
I`m familiarized with wireless routers, in fact I understand how the things going, but if possible I wanna change the language and/or update firmware.
Pls help.
10x
  • this is Cable modem and believe to be ISP specific devices (branded).
    if product support here in netgear support page do not show any firmware downloads then you are stuck with french since branded unit are control by ISP specific firmware
  • I have the same issue, so there is no way i can change the language to English?
  • This unit is provided by ISP. You may contact the ISP who provided you the unit on how to change it.
