MEIJER
Apr 06, 2016Follower
Change Password
I have model WNDR4300 Avast Anti-virus reported my NETGEAR 79 router had changed its key to ADMIN. This has happened without my knowledge or any intervention. My first question is how can this hap...
netwrks
Apr 06, 2016Master
Have you ever changed the default router password and wifi passphrase? If you haven't you should. That would be one of the first things that should be done when configuring the router for the first time.
In respect to firmware upgrades, you may get an automatic notification of available firmware, or better yet, go to the Netgear site and check for new firmware. Ensure you read the Release Notes first, when considering a firmware upgrade.
Kelliehwhite2
Jul 28, 2016Aspirant
How do you reset the password and pass phrase ac1750 wifi cable modem router.
Thanks Kellie
- DarrenMJul 29, 2016Sr. NETGEAR Moderator
Hello Kelliehwhite2
If you have forgot the password you will have to factory reset the modem by holding the reset button down on the modem for 10 seconds then it will be admin/password. If you know the current password log into the by going to www.routerlogin.net then go to Advanced-Administration- set password.
DarrenM
