crudolphy
Dec 18, 2019Aspirant
change router to modem
I am receiving a "double NAT" error. I wish to change my router to be a modem only but cannot find instructions. The instructions posted on this website do not work. These instructions indicate there...
crudolphy
Dec 19, 2019Aspirant
Thanks for the response. I am receiving an error saying I have a "double NAT issue". After reading an article about double NAT, I thought I needed to change my router/modem to be a modem only. I did not realize that my device WNDR3700 was a router only. So that will not fix my issue. I will have to try something else. Thank you for the prompt response. It has helped me refocus my efforts.
antinode
Dec 19, 2019Guru
> [...] I will have to try something else. [...]
As a start, you might try answering the pending questions about your
equipment. For example:
> [...] To what is it connected? Is there some kind of modem involved?
