MountainAresUK's avatar
Feb 20, 2021
changed modems, speed got capped at 100mbps
I haven't been able to find the same issue already present in the community, so here it goes...   My ISP changed my old router for a new model, that's when the problems started, my netgear switch h...
  • MountainAresUK's avatar
    MountainAresUK
    Feb 21, 2021
    Well that's a bit disappointing...
    I already had figured out it was the switch, should it be anything else I would not come to the NG community, rather would do some further troubleshooting.
    So It's either NG warranty or not NGs problem at all? Why would the support site point towards the community as a way to find a solution to the problem?
