mvp4321
Apr 06, 2022Aspirant
Changing CAX30 password
Came back from vacation to find that my CAX30 Router had switched back to the default password. I went in to change the password, but Netgear won't accept my passord (even though I went to the main N...
mvp4321
Apr 08, 2022Aspirant
My wifi router account
michaelkenward
Apr 08, 2022Guru - Experienced User
What's that?
What asks for it? And what are you doing when that happens?
Do you mean the password for the wifi?
You can change that yourself.
As plemans says, if you can't login to the router's graphical user interface (GUI) then you may have to reset the device.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
