MichaelAN
Apr 16, 2020Follower
Changing factory password
How do I change the factory-set password on the modem/router? I would like to make it simpler.
Thats not changable. That needs to be the same always so if a modem is reset you can access it with that same factory password. The setup wizard has users set there own admin user custom password when walking thru the setup wizard.
> How do I change the factory-set password on the modem/router? [...]
Which one? Visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual. Read. Look
for "Types of Logins", "Change the admin Password", and "Specify Basic
WiFi Settings".
