Teakey's avatar
Teakey
Changing settings on my AC1600 wifi cable modem router without being conected on a wifi device?
dont know what to type here
  • antinode's avatar
    antinode
    Nov 18, 2017
       How about a clear explanation of what you did, and what happened when
    you did it?
    > need to know how to get into netgear wizard to change stuff from my desk
    > top [...]
       Use a web browser?  What is your "my desk top"?
    > keep getting page saying you must be on wireless device to acsess.
       When you do what, exactly?
       Are you getting the page which says, "You are not connected to your
    Router's WiFi network. [...]"?  If so, then welcome to what may be the
    worst error message in the world.  For an explanation, try:
          https://community.netgear.com/t5/x/x/m-p/1365830
       Briefly, the idea is that "[www.]routerlogin.net" should point to
    your own router, but that's true only if you use your own router for DNS
    name resolution.  Irregardful, you should be able to get to the thing
    using its IP address, if you can determine (or guess) that.
       "AC1600" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the label.
       The User Manual for your router should tell you what its default LAN
    IP address is.  Look for "192.168.".  Otherwise, you can often get it
    from your (unspecified) computer's IP configuration as the default
    gateway or router address (or some similar description).  Visit
    http://netgear.com/support , put in your (actual) model number, and look
    for Documentation.
