canuk211
Apr 09, 2022Follower
changing ssid name and password c7100v
I am trying to change name and pw for my c7100v router. When logging into router and I get to the STUPID security questions, this is what happens... 1st Q- what is oldest sisters name? (I only have...
michaelkenward
Apr 10, 2022Guru - Experienced User
1st Q- what is oldest sisters name? (I only have 1 sis) So I answer: Erica
2nd Q- what city mom born in?( only 1 mom) Toronto
Reply is...incorrect info..............?#$@!?/////???.
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
