BoboGin's avatar
BoboGin
changing the logon address on CM1100
I just replaced my old Zoom with a CM1100. Works great, I am adding a second connection to the system for my home business. While I can curerntly get to the 192.168.100.1 address to manage the first CM1100, how do I change the address so that the second modem will also be addressable.
  • FURRYe38's avatar
    The .100.1 is not changable as this is a static address so users can address the CM modems web page only. This doesn't effect connected devices. You can connect, say two routers to the back of the CM modem, power OFF the CM modem and two routers. Power ON the modem and let it sync, then power ON the two routers. If your ISP assigns the one modem two separate WAN IP addresses, then each router connected to the modem will get a different WAN IP address.
    • antinode's avatar
      antinode
      Guru
      > [...] I am adding a second connection to the system for my home
      business. [...]
         What, exactly, does that mean?  Another co-ax cable, or another
      external/public IP address, or what?
      > [...] how do I change the address so that the second modem will also
      > be addressable. [...]
         "second modem"?  See previous question.
         In general, I see no easy way to manage multiple cable modems from
      one LAN.  But, with no idea what "second connection" means to you, or
      how, exactly, you intend to use it, it's tough to be confident of much.
      > [...] You can connect, say two routers to the back of the CM modem,
         Depending on the Internet service provided by your (unspecified) ISP,
      that may or may not make sense.
      • BoboGin's avatar
        BoboGin
        Thank you for the response, that does become problematic for me. I have a router that load balances between multiple connections. Both of these systems would be on separate WAN ports but part of the same network.  If I could make a suggestion to your product team, this address should be editable. If for no other reason then to let the consumer get status information from the device if more than  one of them are deployed. It may have been a rare case, but with more of us working from home, it may be more regular. I have my home network which I pay for, and now my company wants me to have a separate network to user for VPN access to the company. So they put in a separate service, with a dedicated IP address on the public network. To accomodate that, they also provided me with a basic home router that can connect to both WAN connections, but  since these have the same management IP, I cannot manage them unless I turn one of them off.
