ericandrenee
May 26, 2016Follower
changing wireless passsword thats not supported by genie
My router isnt compatible and i need to change my password
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello ericandrenee
You will need to be connected to your network and then go to the website 192.168.0.1 or 192.168.1.1 and then it should prompt you to log in you will want to use admin/password for the login then you should be able to go to wireless settings and change your password.
DarrenM
