Laryke
Mar 23, 2022Apprentice
Channels bonds
Hello, I got this new modem and I have few problems, one is that hour time do not match, because of spring hour change (I do not think this is a problem), also I have few criticals and warning on eve...
Mar 23, 2022Guru - Experienced User
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Once you've done that. try it, if it doesn't help, take a screensnip of the cable connections page and event logs and post back here.
- LarykeMar 23, 2022Apprentice
I tried some of the things you said and now I got this, the only warning, rest of them are notices
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
But I do not understand why 4 of them are not locked
Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 41.5 dBmV 2 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 41.5 dBmV 3 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 41 dBmV 4 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 40 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
