Laryke
Mar 23, 2022Apprentice
Channels bonds
Hello, I got this new modem and I have few problems, one is that hour time do not match, because of spring hour change (I do not think this is a problem), also I have few criticals and warning on eve...
Laryke
I tried some of the things you said and now I got this, the only warning, rest of them are notices
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
But I do not understand why 4 of them are not locked
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Mar 23, 2022Guru - Experienced User
Its pretty standard for only 4 of the upload to lock.
But it helps if you have the screen snips of upload/download the the logs.
- LarykeMar 25, 2022ApprenticeSorry for late answer, problems at work
Uncorrectables 0 for everyone- plemansMar 25, 2022Guru - Experienced User
So the screensnips are just a snip in time of when you loaded the page.
And your values are just a bit high. Not horribly high but enough that if the power fluctuates, you can end up getting the "dynamic power" warnings and t3 errors.
You can try using a double or triple (start with double) splitter and put in line. that'll drop the power a little bit Hopefully enough to keep it in range. Just make sure to use a high quality one and good cables.
- LarykeMar 25, 2022ApprenticeI have xfinity cable there any better than that? Also I think one head cable is bent. I have splitter but outside, should I get one for a double splitter inside?
