smichal64
Aug 22, 2022Tutor
Channles 1-3 Not Locked on C6300v2
Channels 1-3 Not Locked on C6300v2 which is giving me an orange light on my upstream indicator. How do I get those channels locked to fix this?? My ISP is Xfinity.
smichal64
Aug 22, 2022Tutor
smichal64
Aug 22, 2022Tutor
The attached screen shot shows the "not locked" channels
- smichal64Aug 22, 2022Tutor
Also as far as wiring in the building goes.. I'm in an apartment building : ( probably not a lot I can do on that front.
- plemansAug 23, 2022Guru - Experienced User
Someones got a booster/amplifier in line somewhere or there's something causing increased power demands in the line. Reason I say that is the level of your downstream to the upstream. Your event logs might help see if theres connection issues but so far it looks like there is. And if you're in an apartment, having the ISP check it might be your only option. Just make sure to check the connections that you can inside the apartment to make sure you don't have any extra splitters/amplifiers/or signal attenuators.
- smichal64Aug 23, 2022TutorThank for the input, yeah I’ve checked all of them and none of the coaxial outlets have anything attached to them. We just moved in so there was nothing in the apartment to begin with.
