mtrotman
Sep 29, 2017Guide
Chronic Connection Issues with Nighthawk X4S AC3200
I've totally given up trying to get this router/modem to work properly and consistently with my environment. Perhaps if one has a very simple home network with a computer or two it may be fine, but i...
DarrenM
Oct 03, 2017Sr. NETGEAR Moderator
Hello mtrotman
Have you tried to change the wireless channel of the wireless or even try to reserve the IP address of those devices to make sure its not a IP address conflict issue that is happening?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
DarrenM
- mtrotmanOct 03, 2017Guide
I’ve change the channel many times. When I asked the Netgear tech about reserving the IP address she told me that was not a viable solution. If you’re telling me otherwise, I’ll be glad to give it a try. I really want this modem to work.
- mtrotmanOct 05, 2017Guide
Okay, so I went through the tedious process of reserving an IP address for every device connected to the network. This did absolutely NOTHING to solve the problem. I can't even print.
- vkdeltaOct 06, 2017NETGEAR Employee Retired
Hi,
Can you please upload Event logs, network logs, attached devices logs here?
Can you please upload DOCSIS power table?
are you loosing WIFI connectivity or INTERNET connectivity?
who is your ISP to which this C7800 is connected to ?
Is it running 3.1.36 FW?
- mtrotmanOct 19, 2017Guide
I fixed this problem by unchecking the box for ENABLE Airtime Fairness
