Asjb123
May 20, 2019Tutor
Climbing uncorrectables cAnnot pinpoint problem....
So long story short cables have been replaced. “ spectrums claimed to run a new drop cable... every time a tech comes out he says signals are good and everything checks out fine on his meter. No spli...
Asjb123
May 20, 2019Tutor
That was taken 30mins after a hard reset. . And this modem was replacement due to the tech taking a shot in the dark just because I’m not using there spectrum modem.
And it’s weird because there’s no errors in log except for one cm status event type code 24.. also speeds haven’t been an issue. . Just intermittent lag while gaming...or streaming other than that you wouldn’t notice it.
May 20, 2019Guru - Experienced User
Something you can check with NG support about and see:
