Allendreke59
Apr 03, 2019Aspirant
Closed caption trouble
C6300 need check media speed and that closed caption jam up by media sped off must right middle of speed not by pixel
schumaku
Apr 03, 2019Guru - Experienced User
Uh... reads like French to me.
- Allendreke59Apr 11, 2019AspirantEnglish for hard of hearing and deaf
- schumakuApr 11, 2019Guru - Experienced User
Must admit I tried to understand the text, and ignored the subject a little bit or failed to build the connection - I'm sorry for that.
Where and how does the C3600 come into play on closed captions (CC, TV/video subtitles)?
The cable modem/router is not in the data path for the digital cable (DTV) signal, which does carry the CC information for example.
- Allendreke59Apr 11, 2019AspirantIn YouTube video that have close caption same as subtitles so when modem got jum up the wire and WiFi is got weak signal that video and sound work fine but not close caption or subtitles is messy word also some time when automatically sign in through WiFi got error on password sound like Burn up the modem and should have speed 150 mbps only I get 90 mbps like not use it pass 8 hours then reboot that I got 160 mbps after four hours is drop down to 90 mbps maybe got virus ?
