roger1955's avatar
roger1955
Apprentice
Mar 02, 2018
CM 1000 Connections
Hello, Got rid of Xfinity gateway and bought the Netgear R8000P router and CM 1000 modem. Could someone please take a look at my modem signals and advise. Thanks so
  • DarrenM's avatar
    Mar 09, 2018
    The levels look ok are you able to post any of the modem logs? also what is the issue you are having.
    DarrenM
