Ziadturk
May 26, 2017Aspirant
CM 1000 help needed
hello, This is my first cable modem, I had century link ADSL, today I installed the CM1000, with COX, for wireless i connected the old ASUS RT-AC68R Wireless-AC1900 Router I was using previousely...
- May 31, 2017
Hello ZIadturk
The CM1000 is a modem only it does not have a router built into it you need a router connected to it to do those type of settings.
DarrenM
DarrenM
May 31, 2017Sr. NETGEAR Moderator
Hello ZIadturk
DarrenM
- ZiadturkMay 31, 2017Aspirant
Thank you Darren,
I am used to Modem/Routers, this is why I was confused, thank you for your reply, I wanted the fastest available modem, so, I chosed the CM1000, but, I thought that the GUI would give me more details, or ways to configure, but, I see now that most of the setting/info I need are within the router interface. I think I should also upgrade my router I have the Asus RT-AC68 (AC-1900), any recommendation ??
