Ziadturk's avatar
Ziadturk
CM 1000 help needed
hello,   This is my first cable modem, I had century link ADSL, today I installed the CM1000, with COX, for wireless i connected the old ASUS RT-AC68R Wireless-AC1900 Router I was using previousely...
  • DarrenM's avatar
    May 31, 2017
    Hello ZIadturk
    The CM1000 is a modem only it does not have a router built into it you need a router connected to it to do those type of settings.
    DarrenM
