jghayes
May 12, 2021Aspirant
CM 1000 VPN?
I have CM 1000 and I am trying to figure out if it is VPN capable. Does it have a VPN built in? I checked and it is not compatible with Express VPN. Thanks
May 12, 2021Guru - Experienced User
The CM1000 is a modem only. No router or VPN featuers. VPN would be handled at a router or connected client level and would just pass thru the CM modem.
jghayes
ok, I'm a networking rookie. My modem passes to a Ubiquiti USG gateway so I'm assuming that is where the VPN will reside.
