binghambj22
Jul 17, 2024Aspirant
CM 1000v2 Going In and Out 100+ Times a Day
Hello! We've been having a lot of trouble with our wifi staying connected, so I'm hoping for some insight. The wifi will connect, then go out, connect and go out. There's no pattern. And the Modem go...
- Jul 17, 2024
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Jul 17, 2024Guru - Experienced User
Your cable connections page helps in conjunction with the logs.
From looking at them briefly, you still have line issues. You're getting T3 errors, dynamic range window violations, power issues. Etc.
Not saying it couldn't be the modem as they do go bad but we usually start with those errors.
