binghambj22
Jul 17, 2024Aspirant
CM 1000v2 Going In and Out 100+ Times a Day
Hello! We've been having a lot of trouble with our wifi staying connected, so I'm hoping for some insight. The wifi will connect, then go out, connect and go out. There's no pattern. And the Modem go...
- Jul 17, 2024
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Jul 17, 2024Guru - Experienced User
binghambj22
Jul 25, 2024Aspirant
We contacted the ISP and they checked. The modem needed an update. That helped temporarily. Then it returned to what it had been doing previously. The line is doing fine. We connected a different modem and we've had no problems since.
I think the Modem may have been the problem sadly.
Thanks!
Thanks!
- FURRYe38Jul 25, 2024Guru - Experienced User
Would need to see the cable connections data page from the CM1000 to better determine if the CM could be the issue or a signal on the line would be the cause. The modem already saw issues in the event logs which point to a signal problem on the line up to the CM modem.
- binghambj22Jul 25, 2024AspirantWe've disconnected, because we needed wifi, so I can't gain access to it at the present time. The new modem works well, so it wouldn't be the line that is causing it. The ISP has been to our house 3 times to check. They haven't found a problem with the line any of those times.
The problem was the modem. We are considering taking the modem to a repair shop.- FURRYe38Jul 25, 2024Guru - Experienced User
Not ruling out a faulty modem, However would still need to see the cable connections page to determine that. Again, the event logs show something on the ISP line needs to be looked at.
Something to try as well, test the CM modem out at a different location, say a friend or or families place and connect it there. Observe and get cable connections and event log data page information.
