ashmak
Mar 20, 2023Tutor
CM 1100 does not show login window
My modem CM 1100 does not show login window at http://192.168.100.1 Is there any solution? I am following these steps: Launch a web browser from a computer that is attached with an Ethe...
Kitsap
Mar 20, 2023Master
ashmak wrote:My modem CM 1100 does not show login window at http://192.168.100.1
- Launch a web browser from a computer that is attached with an Ethernet cable to the cable modem or from a computer that is connected to a WiFi router that is attached with an Ethernet cable to the cable modem. - Done
- Enter http://192.168.100.1. into the address bar of your web browser.
- Click or tap Enter.
A login window displays. - No login window displays?- Enter the cable modem user name and password.
Note: The user name is admin and the default password is password. The user name and password are case-sensitive.
The BASIC Home page displays.
Clear the cache on the web browser you are using.
Try a different web browser than the one you are using.
You using a Windows computer or iOS?
- ashmakMar 20, 2023Tutor
I did that but it doesn't help.
I used Safari and Chrome on my MacBook Pro. I also tried on my iPhone. For router, login window opens quickly at 192.168.1.1 but not for Modem.
- FURRYe38Mar 20, 2023Guru - Experienced User
What brand and model is the router connected to the CM modem?
Power off the modem and disconnect the wifi router from the modem and connect 1 wired PC to WAN port#1. Power ON the modem, after it's ready can you connect to the modem at 192.168.100.1 at all?
