ashmak
Mar 20, 2023Tutor
CM 1100 does not show login window
My modem CM 1100 does not show login window at http://192.168.100.1 Is there any solution? I am following these steps: Launch a web browser from a computer that is attached with an Ethe...
Mar 20, 2023Guru - Experienced User
What brand and model is the router connected to the CM modem?
Power off the modem and disconnect the wifi router from the modem and connect 1 wired PC to WAN port#1. Power ON the modem, after it's ready can you connect to the modem at 192.168.100.1 at all?
ashmak
Mar 20, 2023Tutor
Router is Orbi RBR50
The Modem does not have WAN port. It has LAN 1 and LAN 2. Do I connect my computer to LAN 1? Here is the photo of back of my modem.
- KitsapMar 20, 2023Master
Use LAN 1 for your Ethernet connection. Leave LAN 2 empty. The CM1100 supports link aggregation which your RBR50 does not.
