Tucson_Jim
Mar 07, 2023Star
CM 1100 no longer xFinity Compatible
The CM 1100 cable modem is no longer compatible to use with xFinity. They can no longer see or talk to the modem. On their webpage they show INCOMPATIBLE BASED ON FILTERS. Customer service confir...
- Mar 07, 2023
The the CM has LAG support, base speed support is for 1Gb and in most cases home users don't use LAG. Even the WAN ports are only rated at 1Gb per port so technically, the CM1100 reaches this limit on a single 1Gb line.
We know the ISP recently split there speed tier last year, now 800Mpbs and 1.2Gb. Were seeing problems with some other modems that only support 1Gb on the WAN and LAN side and the ISP up'd the speed to 1.2Gb. The ISP has not certified these modems for 1.2Gb services. So this change is on the ISP side.
One thing to try, have the ISP set your speed package at 800Mpbs.
Another would be to test the CM1100 at a different location, friends or family that may have a different ISP service or speed tier and see if the modem responds differently there.
Or find something that handles 1.2Gb or higher speeds. NG CM2000 series comes to mind since those have 2.5Gb WAN port.
Mar 07, 2023Guru - Experienced User
Should be compatible.
Possible something happening between the ISP service and the modem.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Try a factory reset on the modem by pressing the reset button for 10 seconds then release.
Be sure to power OFF the modem for 1 minute then back ON.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Can you try a different modem to see if something else works or sees a problem?
Tucson_Jim
Mar 07, 2023Star
No Joy on any of that. xFinity says not compatible based on filters. Need to know what that means & how to resolve. This is a Netgear issue. xFinity cannot see or talk to modem like it was able to do in the past.
Cannot access modem through router (another Netgear RAX 78 product). Cannot access modem directly.
