chuellio
Aug 04, 2020Aspirant
CM 1100 Only Getting 300 Mbps with Comcast 1 Gbps Service
I set up a Nighthawk CM 1100 cable modem with a Nighthawk 7000 Wifi router (yes I had two separate devices). I was only ever able to get 320 Mbps (in the same room) on my 1 Gbp connection with Comca...
Aug 04, 2020Guru - Experienced User
Did you first test a wired PC connected to the back of the CM1100 modem when it was connected?
If you were trying to test wireless with the R7000. then this would be your problem. You'll not see anything near 900Mpbs on wireless let alone on the R7000 router. Wireless AC usually maxes out at around 400-500Mpbs on 5Ghz AC if conditions are right. I don't think the R7000 is capable of wired speeds near 900Mpbs. Not fully sure if the R7000 has hardware Nat acceleration support which is needed to achieve anthing near 900Mpbs on the ethernet. I know th R7800 has this nat accelleration support.
I know the CM1100 is well capable of near or over 900Mpbs wired WAN to LAN speeds. I know mine is. Had mine online on a 1Gb service and it works well.
- chuellioAug 04, 2020Aspirant
When logging into the Nighthawk admin portal, it lists 1300 Mbps as the max speed for the 5Ghs frequency. Regardless, I tested the wired connection on the CM 1100, set up the port agregation, and I still could only get 300 Mbps direct from the modem to the Laptop. I tried several Internet tesing sites and that was the high end of the measurement.
- FURRYe38Aug 04, 2020Guru - Experienced User
LAG should be disabled on the CM1100, unless you have a router that supports it, which the R7000 does not, LAG should be disabled.
I would have the ISP check the configuration file again and make sure the modem is fully setup.
Be sure your laptop or PC can also speed test with near 900mpbs wired speeds. Some older singla or dual CPUs don't support high speed testing. Try another PC or laptop to comare.
Be sure to use Ookals installable speed test app. Use a web browser may not give most accurate results.Also be sure to try different speed test servers with Ookla. Different servers maybe busier then others.
- chuellioAug 05, 2020Aspirant
As I said, I tested every configuration, and I was only able to get 320 Mbps. I setup the Comcast modem/router and I was able to get 600 Mbps over Wifi two rooms away and a floor below on the exact same devices that the other set up was tested on. Sure. I could call Comcast and spend about two hours on the phone with them again (my shortest call with them has been 30-minutes and that was to set up their equipment), but why would I do that when I can plug their equipment and the issue is fixed? To save $15 a month? It's not worth my time.
