chuellio
Aug 04, 2020Aspirant
CM 1100 Only Getting 300 Mbps with Comcast 1 Gbps Service
I set up a Nighthawk CM 1100 cable modem with a Nighthawk 7000 Wifi router (yes I had two separate devices). I was only ever able to get 320 Mbps (in the same room) on my 1 Gbp connection with Comca...
chuellio
Aug 05, 2020Aspirant
There's a little cross next to the speed listed in the product listing that says,
MaximumwirelesssignalratederivedfromIEEE802.11specifications.Actualdatathroughputandwirelesscoveragewillvaryandmaybeloweredbynetworkandenvironmental conditions, including network traffic volume and building construction. NETGEAR makes no representations or warranties about this product's compatibility with future standards"
My mistake. I didn't read the fine print. I won't make that mistake again. As fun as it is to debate Wifi tech specs ad infinitum, I'm moving on to something more productive. Thanks.
Aug 06, 2020Guru - Experienced User
Good Luck.
