sbarr0
Apr 16, 2019Aspirant
Cm-1100
With the cm-1100 having two Ethernet ports, can I plug my router in one and pc in the other. Or is the two ports only for the redundancy with the appropriate nighthawk router?
- Apr 16, 2019
Most ISP's only supply one ip address unless you pay for more (multiple IP's or 2gbps speeds) . Plugging a computer into the 2nd port will only create problems with connecting your router. connect your router to the one port and let it handle the routing :)
Apr 16, 2019Guru - Experienced User
- sbarr0Apr 17, 2019AspirantThanks!
