TheKillFloor
Jul 28, 2019Aspirant
CM 1200 - Multiple Ports
OK, so I am a n00b with networking stuff. I have the CM1200 and it has four LAN ports. Am I able to connect one port to my wireless router to provide service to wifi connected devices and another mod...
- Jul 30, 2019Thank you for the help!
Jul 29, 2019Guru - Experienced User
No, the 1200 only supports the use of 1 external device or a external router. If LAG is enabled on the modem then you can connect a LAG supporting router to two of the ports for LAG support. The other ports are for multiple WAN IP addressing from ISPs.
TheKillFloor
Jul 30, 2019Aspirant
- FURRYe38Jul 30, 2019Guru - Experienced User
The R7960P router supports LAG on it's WAN side.
:smileywink:
