davids87
Jun 06, 2021Aspirant
CM 1200 not connecting to internet
Power went out and my CM1200 cannot longer connect to the internet. I just with the cable company, and they could not communicate with the device. All the lights are on, but the Internet li...
Jun 07, 2021Guru - Experienced User
You connected your old router or modem?
do you have other devices connected to the cm1200?
- davids87Jun 07, 2021Aspirant
No, I connected my old modem just to test if the internet was working from the provider side, and it is. This old modem is connect to my wifi router.
The CM1200 modem is now just connected to electricity
- FURRYe38Jun 07, 2021Guru - Experienced User
Did you connect your wifi router to the CM1200 modem after you go the modem associated with the ISP service first?
davids87 wrote:No, I connected my old modem just to test if the internet was working from the provider side, and it is. This old modem is connect to my wifi router.
Yes, the wifi router was connected to the CM1200 modem and it was working fine for a few days.
The CM1200 modem stopped working and the "world symbol" light was blinking green. I called the internet provider, they told me they could not communicate with the modem. I called Netgear, they told me it had to do something to do with the "channels", that the CM1200 modem needed to be reset and reconfigured.
Netgear told me that it was something (the resetting and reconfiguration) that I could do from my end, or that if I paid a fee they could do it from their end. I am trying to find the instructions or the way I can do it from my end.
I connected my old modem so I could have internet until the issue with the newer CM1200 modem is resolved.
