orangesmoke20
Mar 01, 2017Aspirant
cm 400 amber upload / download lights
my upstream and downstream lights just turned orange.. i called netgear they said it was my isp, i called my isp and they said its netgears problem
DarrenM
Mar 03, 2017Sr. NETGEAR Moderator
Hello orangesmoke20
When those lights go orange it means only 1 up and down stream channels are being locked so it is some type of issue with the internet connection with the ISP you will have to contact them and ask for higher internet support.
DarrenM
orangesmoke20
Apr 26, 2017Aspirant
after some back and forth i finally got my isp to send out a tech and everything came up perfect on their meter.. they suggest my router has either failed or some kind of compatibility with the firmware... i seem to have the latest issued firmware.. do i just buy a new modem? not sure what else to do
