TheCoppola
Apr 27, 2020Aspirant
CM 500 constantly disconnecting - Lots of T3 and T4 & Dynamic Range Window Violation errors
Model:CM 500 IPS: Mediacom Virmware: 1.01.04 There are times when it works fine for extended periods of time throughout the day, but all day everyday I'm dropping connection, both up/down stream i...
- Apr 28, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Apr 28, 2020Guru - Experienced User
- TheCoppolaMay 05, 2020Aspirant
Thanks for the feedback. I ended up calling my ISP and a tech came on site. They made some changes in preparation for 1gb speesds in my area back around October 2019 when this problem first started. He stated that I had an old coaxal splitters from their box on the street to the d-mark outside my house which was for the old signal. Still getting a little noise on their end but its down the line and he placed a ticket with their field guys. Over all its been much better but could be even better once they clear that noise down the line (if they find it).
