jbaugh
Feb 24, 2018Aspirant
CM 500 Modem connection drops
Several times a week I have to reboot my Netgear CM 500 modem to re-establish my download and upload speeds. Download speed drops to less than 1Mbps when I am rated for 30Mbps. Often I havce to reb...
DarrenM
Feb 28, 2018Sr. NETGEAR Moderator
Are you getting T3 and T4 timeouts in your event logs?
DarrenM
- jbaughFeb 28, 2018Aspirant
Yes, I am getting very frequent T3 timeouts. No T4 timeouts. The T3 timeouts occur as often as every 3 minutes but usually every 6-18 minutes.
John
- DarrenMMar 01, 2018Sr. NETGEAR Moderator
Yea something is wrong with the connection from comcast it could be out in your neighborhood or even wiring in your home you will have to get comcast to send a tech out to investigate the lines.
DarrenM
- jbaughMar 01, 2018AspirantThis has been going on for at least 6 or 7 months. The comast tech came out. He refused to look at the modem logs. I showed him the results of line testing and smoke pings on dslreports.com that documented the repeated loss of packets and extremely high ping times (400+ msec). “It’s not a problem with Comcast. Everything checks out fine. It is your problem”. This despite the fact that I’ve switched out my modem and my router with the same results.
