Burdell's avatar
Burdell
Tutor
Sep 03, 2020
CM 500 MODEM Question
Hi There..Just goit a CM500 Modem to replace my Comcast..Are the 4 Ethernet ports on the back of the CM500 Ethernet out?
  • Thanks for your reply...I made a mistake.I meant the ports on my RAX 45 Router..
    I found out that they are indeed LAN Out.
  • plemans's avatar
    The cm500 is a modem only so there's only 1x ethernet port out. If you have 4x ethernet ports, you don't have the cm500.
    • Burdell's avatar
      Burdell
      Tutor
