rightintel's avatar
rightintel
CM-500 Slow speeds, shows weak signal on ISP's end
Modem is CM500, Cox is ISP. MY speeds have dropped to half of capacity in the last month(down to 160mbps). Mac OSX 10.11.6, Apple Time Capsule router(2014). Have done all the power cycling, rebooting modem/router, etc. Modem is under hardware warranty til 2/7/17.
Here's the modem log:
1970-1-1, 00:00:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:36 Notice (6) Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:38 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.0;CM-VER=3.0;
2016-12-27, 16:52:03 Notice (6) TLV-11 - unrecognized OID;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-27, 16:52:46 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:19:00 Warning (5) Dynamic Range Window violation
2016-12-29, 11:20:16 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:24:44 Warning (5) Dynamic Range Window violation
2016-12-29, 11:25:30 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:25:44 Warning (5) Dynamic Range Window violation
2016-12-29, 11:26:00 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:27:58 Warning (5) Dynamic Range Window violation
2016-12-29, 12:03:08 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:04:06 Warning (5) Dynamic Range Window violation
2016-12-29, 12:04:22 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:05:21 Warning (5) Dynamic Range Window violation
2016-12-29, 12:06:37 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:06:51 Warning (5) Dynamic Range Window violation
2016-12-30, 11:31:12 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-30, 11:59:35 Warning (5) Dynamic Range Window violation
2016-12-31, 04:52:00 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-31, 17:24:58 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-3, 16:52:00 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 11:40:05 Warning (5) Dynamic Range Window violation
2017-1-8, 11:41:21 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 11:59:16 Warning (5) Dynamic Range Window violation
2017-1-8, 14:31:11 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:14 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:18 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:35 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:38 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:44 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
Help Center
  • Yup, it looks like the modem is having trouble communicating with the ISP's CMTS.  You should ask the ISP to investigate.  In the meantime, make sure that you eliminate as many coax splitters between the modem and the coax cable coming into the house as possible.  This will help ensure that the modem receives the strongest signal as possible from the ISP.
    • rightintel's avatar
      rightintel
      Thanks. They checked(level 2 support) and said the signal end everything was fine on their end. They said the modem was having power(volts or amps or something to that effect). So is this a hardware problem or what then? It's outta warranty in a month, so I need t figure out what to do...
      • TheEther's avatar
        TheEther
        Guru
        There's not enough information to tell whether or not it's a hardware problem.  You can also check the signal levels on your modem.
        Did you remove any unnecessary splitters?
