rightintel
Jan 08, 2017Aspirant
CM-500 Slow speeds, shows weak signal on ISP's end
Modem is CM500, Cox is ISP. MY speeds have dropped to half of capacity in the last month(down to 160mbps). Mac OSX 10.11.6, Apple Time Capsule router(2014). Have done all the power cycling, rebooting...
rightintel
Really appreciate your help. I've factory reset the modem and router before I pulled these, so these may not be helpful:
Acquire Downstream Channel 819000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 4 819000000 Hz 9.8 dBmV 41.2 dB 0 0
2 Locked QAM256 1 801000000 Hz 10.4 dBmV 41.8 dB 0 0
3 Locked QAM256 2 807000000 Hz 10.1 dBmV 41.6 dB 0 0
4 Locked QAM256 3 813000000 Hz 10 dBmV 41.5 dB 1 0
5 Locked QAM256 5 825000000 Hz 9.3 dBmV 40.8 dB 1 0
6 Locked QAM256 6 831000000 Hz 8.9 dBmV 40.6 dB 1 0
7 Locked QAM256 7 837000000 Hz 8.6 dBmV 40.4 dB 3 0
8 Locked QAM256 8 843000000 Hz 8.3 dBmV 40.2 dB 2 0
9 Locked QAM256 17 897000000 Hz 6.1 dBmV 39.4 dB 22 0
10 Locked QAM256 18 903000000 Hz 5.9 dBmV 39.2 dB 14 0
11 Locked QAM256 19 909000000 Hz 5.2 dBmV 38.9 dB 36 0
12 Locked QAM256 20 915000000 Hz 4.8 dBmV 38.7 dB 41 0
13 Locked QAM256 21 921000000 Hz 4.3 dBmV 38.5 dB 31 0
14 Locked QAM256 22 927000000 Hz 4 dBmV 38.2 dB 28 0
15 Locked QAM256 23 933000000 Hz 4 dBmV 38.3 dB 36 0
16 Locked QAM256 24 939000000 Hz 3.6 dBmV 38 dB 37 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 2 5120 Ksym/sec 23300000 Hz 45 dBmV
2 Locked TDMA and ATDMA 1 2560 Ksym/sec 18400000 Hz 45 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29800000 Hz 44.9 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 36300000 Hz 43.4 dBmV
Current System Time:Sun Jan 08 17:29:01 2017
TheEther
Jan 08, 2017Guru
I'm not an expert at interpreting signal levels, but judging from what I know, they look ok. Sorry, I can't be of any more help.
- rightintelJan 11, 2017Aspirant
Appreciate it anyway. Support says it ain't a hardware problem, and there's no way to prove it either. Hopefully it lasts...
