Amanda19
May 21, 2019Aspirant
CM 500 sync timing failure
My modem keeps giving me the same error of: SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing. My cable provider says that its an issue with the modem itself but this t...
Amanda19
There's splitters out there and I made sure they were tight at least. There's no box outside. It's a cable straight from the main line to my house.
May 21, 2019Guru - Experienced User
Remove all splitters temporarily and try again. Possible these splitters are causing problems.
