Zargusvan
Sep 28, 2021Aspirant
CM 500 Uplink/Downlink lights cycling amber
My internet connection are dropping on a monthly basis, it would turn off and automatically turn back on sometimes a day to a week wait time. I'm not sure if the problem is my modem or my isp provid...
Sep 29, 2021Guru - Experienced User
You've only got 1 locked channel. That'll cause lots of issues. And your logs are indicating line issues.
try removing any splitters, amplifiers, or signal attenuators from your line.
Check the coax for damage, kinks, loose/old/bad/corroded connections and replace them if you do.
Preferably move the modem to right where the coax enters the home to prevent wiring in the home from being the issue.
If you're still only locking 1 channel, the ISP needs to actually come check the line.
