ashguptak
Nov 18, 2019Aspirant
CM 600 Network Name unknown
I recently bought a Netgear CM600 cable modem router. Successfully setup the internet activation, however, I am not able to discover the Wifi Network name(SSID Name) to login. The bottom stickers on ...
Nov 18, 2019Guru - Experienced User
The CM600 is a modem only. There isn't a router and therefore is no wifi. You need to purchase a router seperate from modem.
- ashguptakNov 18, 2019Aspirant
I checked with the Comcast operator and she said it is a compatible device for Wifi connection.
- plemansNov 18, 2019Guru - Experienced User
Its compatible with comcast service but its a modem only device. There is no router integrated to it. Netgear makes modem/router combo devices but the CM600 is not one of them.
https://www.lifewire.com/difference-between-modem-and-router-4159854
