llewis01
Feb 16, 2017Aspirant
CM 600
After installing my cm600 cable modem with my isp. It seems that I can not login to the modem. I have tried the ip address and it tell me that connection was reset. Does the isp lock out that option ...
- Feb 16, 2017
Figured out what the problem was. I always use firefox but that didn't work so I microsoft edge and that worked.
Thanks
djc6
Feb 16, 2017Luminary
I've not heard of ISPs blocking access to http://192.168.100.1/ - what ISP do you have?
Have you tried turning it off/on and/or the reset button on back of modem?
- llewis01Feb 16, 2017Aspirant
Thanks
