denovo
May 27, 2021Aspirant
CM100 v2 frequently off-line
We have been losing our internet connection several times/day for several weeks now. A tech came out and fiddled with the box on the outside of the house, saying the last tech who worked on it did st...
May 27, 2021Guru - Experienced User
Ya you got some critical errors that the ISP needs to look into I believe.
https://highspeed.tips/docsis-events/
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- denovoMay 27, 2021Aspirant
I believe that's what I posted as a pdf attachment to the first post in this thread, but I'll try doing it as screen shots and see if that works better... well, out of order, but visible. Are those upstream power levels the likely culprit? And if so, is it fixable from my end??
Well, it looked fine before I clicked to post! WTF? Wish I knew how to use this site properly... my apologies! Isnt a .jpg and acceptable photo? I'll try again with .png files.
- FURRYe38May 27, 2021Guru - Experienced User
No your fine, any inline pictures have to be approved by a forum moderator is all. You can always attach picture files using the Choose File button on the forum post at the bottom of the text box.
