denovo
May 27, 2021Aspirant
CM100 v2 frequently off-line
We have been losing our internet connection several times/day for several weeks now. A tech came out and fiddled with the box on the outside of the house, saying the last tech who worked on it did st...
denovo
I believe that's what I posted as a pdf attachment to the first post in this thread, but I'll try doing it as screen shots and see if that works better... well, out of order, but visible. Are those upstream power levels the likely culprit? And if so, is it fixable from my end??
denovo
Well, it looked fine before I clicked to post! WTF? Wish I knew how to use this site properly... my apologies! Isnt a .jpg and acceptable photo? I'll try again with .png files.
- FURRYe38May 27, 2021Guru - Experienced User
No your fine, any inline pictures have to be approved by a forum moderator is all. You can always attach picture files using the Choose File button on the forum post at the bottom of the text box.
- denovoMay 28, 2021Aspirant
So... Anything showing that tells me what I should be doing to improve stability? Aren't those power levels in the locked upstream bonded channels too high? Range is 50.5 to 52.8 dBmV. Before the last service call I'd get a lot of uncorrectable errors in most downstream channels, but now that seems limited to channel 14. The error log is in a pdf attached to the second post above.
I've powered the modem down multiple times, there are no splitters between the service box and the tap into the house, and the modem is right there. The cable to the modem is the one provided by Comcast, which is, I suppose, no guarantee of quality. As I've mentioned above, the Comcast techs always feel they've done everything by the book but whoever was working before them did it wrong, and they have absolutely nointerest in the error log generated by the modem.
