serobinson2
Jan 02, 2021Aspirant
CM1000 - Optimum/Altice blames speed issues on modem, won't update firmware
Paying for 400 Mbps from Optimum/Altice. (It is literally our only option for ISPs at our building - I have spent three years trying to get Fios on our block or roof access for a MESH dish. Only opti...
- Jan 05, 2021
Well, I caved and rented the official Optimum router. This - of course - didn't fix the issue, since Optimum's line was bad, but it at least convinced them to finally replace the line to our building. As it turns out, nobody in the building had internet for close to a week, and nobody at Optimum pieced that together, since we were all calling separately to an overseas call center....
All's well that ends well? I'm honestly just super relieved to be able to work properly again.
Jan 05, 2021Guru - Experienced User
Sometimes ISPs gotta be shown it's there problem and not the modems.
Glad it worked out.
Please mark your thread and solved so others will now.
Enjoy. :smileywink:
serobinson2
Jan 06, 2021Aspirant
Will do. Wish I had better advice for people finding this thread than "your local ISP monopoly couldn't find it's own rear with both hands and a map," but, well....
sigh.
Now I have this rental modem I have to return. And a lot of catching up after a week of wfh with no internet....
- FURRYe38Jan 06, 2021Guru - Experienced User
At least you can return the modem and continue to use the one you bought.
Enjoy. :smileywink:
