SolePublic
Jul 31, 2019Aspirant
CM1000 - pre-purchase questions
I'm considering replacing my cable modem with a Netgear CM1000. I have a few pre-purchase questions. 1) Apparently CM1000 has the CSRF/LocalFile/XSS vulnerability identified in 2015 https://comm...
SolePublic
Additions
>One difference I found between V1 and V2 in the Product Data Sheets is that V1 specifies Xfinity as a provider and V2 includes other providers. My ISP lists CM1000 as a compatible modem so does it matter which one I buy?
>Is it true that the user can't upgrade the firmware for CM1000 and other Netgear modems - you have to wait for your ISP to upgrade even when you didn't get the modem through the ISP?!
The Netgear support pages suggest this is the case. That might be a deal stopper since I use a small ISP. I'm not sure they roll anything out.
- FURRYe38Jul 31, 2019Guru - Experienced User
Ask yoru ISP which version of the CM is supported. They will have this information.
Most cable ISPs don't allow any user regardless of ISP provided or User bought modems to be updated by the user. ISP hold this responsibility. Some ISP won't update user bought modems. Something else to ask your ISP about. Cable ISPs handle the testing and ceritifcation of modem FW on there systems.
