jp4120
Apr 22, 2021Guide
CM1000 - questions about some issues after 14 months
I have a CM1000 coupled with an Orbi CRB40 - ISP is comcast - they came out last week and removed the inside the basement amplifier and all inside splitters because since i cut the cord i stream e...
Apr 22, 2021Guru - Experienced User
The cm1000 has been a pretty solid reliable modem.
but anything can fail in 14 months. Its always possible.
Do you have a screen snip of the cable connection page and the event logs from the modem?
jp4120
Apr 26, 2021Guide
continues to drop and then restarts - did it 2x today 4/26 - but had not dropped since 4/23 - here is a some of the event log -
- jp4120Apr 26, 2021Guide
2021-04-26, 18:01:37 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:aa:b3:10;CMTS-MAC=00:01:5c:7a:9c:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:aa:b3:10;CMTS-MAC=00:01:5c:7a:9c:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=28:80:88:aa:b3:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:aa:b3:10;CMTS-MAC=00:01:5c:7a:9c:64;CM-QOS=1.1;CM-VER=3.1; - jp4120Apr 26, 2021Guide
i really think its due to the removal of the comcast signal booster/amplifier - even though i had one splitter that was removed when the amplifier was removed my theory is the unamplified signal is causing the occasional drops......having Comcast return and after they tell me for the 3rd time it all looks good i will have them put the signal booster back in.......(instead of just disconnecting the first one the original tech broke it off for some reason)
- FURRYe38Apr 27, 2021Guru - Experienced User
Be sure to have them check the speeds at the modem with your wired PC and have them look at the modem logs while they are there.
