jawnny_five
May 24, 2019Tutor
CM1000 | Solid Amber Lights on everything but power
About a year ago, I set up a CM1000 to work with Comcast (or Xfinity, whatever they want to be called these days) and it worked fine. I have recently moved and decided to keep using my own modem,...
May 26, 2019Guru - Experienced User
Have you check with the ISP to ensure the signal levels on the service line are to spec and not over or under levels?
Check the user manual for default admin log in settings.
Try using a different web browser.
