tim614
Jul 29, 2019Aspirant
CM1000 + WOW Cable, Very Slow Upload Speeds
I've had a weird issue with my CM1000 the past few days. Occasionally my speeds will stick where they are supposed to be (500/50), but occasionally the download declines a bit and the upload drops to...
tim614
Thanks for your reply.
What router are you using? If you directly connect a computer to the modem and use it, does your speed decrease?
- I tested it out on my PS4 Pro, none of my laptops have ethernet ports unfortunately.
- Plugging directly into the modem produces the same speeds as the router. It's a Linksys Router (AC1750)
When the speeds drop, do they resolve on their own or what do you do to fix it?
- I went to sleep one night and it was better in the morning (so I assumed an outage), but down again at night. I haven't found a workaround that works yet.
When the speeds drop, what do the logs show?
- This log was a speed drop one.
Jul 29, 2019Guru - Experienced User
I would test with a PC or laptop with a LAN port. Game consoles are not the most accurate in reporting speed results.
Have the ISP check everything from there side up to the modem.
