hazyvoodoo's avatar
Aug 29, 2019
CM1000 & XR500 Latency Variation and Ping Spikes
Hello!   I have just moved back from Germany to New Mexico and I have just purchased the xfinity 150 down/5 up plan.  The main game I have been playing for close to a year is Battlefield V and whi...
  • hazyvoodoo's avatar
    hazyvoodoo
    Sep 01, 2019
    I finally fixed it.
    I returned the CM1000 (DOCSIS 3.1) for the ARRIS SB8200 ( DOCSIS 3.1) and I still had the issue.
    After a little bit more digging I have been finding the newer DOCSIS 3.1 modems have their own QOS rules and can interfere with gaming routers such as my nighthawk XR500. It's a shame arris and netgear can't provide a way to disable the QOS rules on the modem''s interface.
    I disabled the QOS rules completely on the DUMAOS dashboard and just like that my ping spikes were GONE!
    I would love to have my qos set up again but hopefully netgear can provide some sort of firmware update to fix this issue because spending $170 on a modem and $250 on a router is  rididcioulus and I am not able to use the QOS on the XR500 now until this gets sorted out. The dumaos was the reason for purchase but at least the spikes are gone.
