hazyvoodoo
Aug 30, 2019Tutor
CM1000 & XR500 Latency Variation and Ping Spikes
Hello! I have just moved back from Germany to New Mexico and I have just purchased the xfinity 150 down/5 up plan. The main game I have been playing for close to a year is Battlefield V and whi...
- Sep 02, 2019
I finally fixed it.
I returned the CM1000 (DOCSIS 3.1) for the ARRIS SB8200 ( DOCSIS 3.1) and I still had the issue.
After a little bit more digging I have been finding the newer DOCSIS 3.1 modems have their own QOS rules and can interfere with gaming routers such as my nighthawk XR500. It's a shame arris and netgear can't provide a way to disable the QOS rules on the modem''s interface.
I disabled the QOS rules completely on the DUMAOS dashboard and just like that my ping spikes were GONE!
I would love to have my qos set up again but hopefully netgear can provide some sort of firmware update to fix this issue because spending $170 on a modem and $250 on a router is rididcioulus and I am not able to use the QOS on the XR500 now until this gets sorted out. The dumaos was the reason for purchase but at least the spikes are gone.
hazyvoodoo
Aug 31, 2019Tutor
I also would like to add, that I have never had these issues before.
I purchased the XR500 in Germany and it worked perfectly there.
The new purchase is the CM1000 and I don't think it's liking any router i connect to it.
Sep 01, 2019Guru - Experienced User
You might contact NG support and file a support ticket for the XR500. IF this ping spikes don't happen with the XR in the mix, then the XR needs to be reviewed. Might post about this over on the XR forums as well. Test with current version FW and with v32 or older FW on the XR router.
Good Luck.
- hazyvoodooSep 02, 2019Tutor
I finally fixed it.
